TwinTurbo.NET: Nissan 300ZX forum - typical dead cylinder sound
Subject typical dead cylinder sound
Posted by KasbeKZ(VA) on February 25, 2010 at 9:51 PM
  This message has been viewed 861 times.
In Reply To engine noises posted by Jiro on February 25, 2010 at 09:31 PM
Message smelling fuely means that you're missing spark, not fuel. one
cylinder is not firing. do a balance test to find which
cylinder, then check your connection, test your coil pack, and
test for current to the coil pack. a balance test involves
pulling each coil pack plug one at a time while the car is
running, and seeing which ones change the way the car runs.
the one that doesn't affect sound or idle speed is the one
that is not firing. do your tests on that one.
